A lot of tractors have been converted to 12 volt negative ground, and a lot have been cobbled on electrically.
The safest answer will be found by following your cables. Your chassis is your ground. Start with the positive terminal of your battery and follow the cable. If it bolts to some part of the chassis without being interrupted by switches, etc., then you have a positive ground. If that isn't the case, trace the cable back from the negative terminal of the battery and see if it runs directly to ground. If it does, then you need to explore whether you're set up for 6 or 12 volts.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
