Re: MD starts hard on gas
Posted by Bob M on April 03, 2008 at 07:11:22 from (151.190.254.108):
In Reply to: MD starts hard on gas posted by WadeMN on April 02, 2008 at 20:35:49:
Somehow your engine is running lean in the gasoline mode. Possible causes:
- Obstruction in the carb fuel circuit (sounds like you've already checked for this)
- Carb float level set too low. Or the float lockup linkage is not letting the float drop all the way when it's in gas mode.
- Carb air valve disc gap set too wide (the gap is adjustable on early carbs - not sure if it is on the later ones...)
- Manifold butterfly valves are not closing fully in gas mode (linkage adjustment or damaged butterfly plate(s)).
- Air leak at the carb or head manifold gasket.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
