Posted by El Toro on April 03, 2008 at 16:15:43 from (205.188.116.73):
In Reply to: Timing marks on 46 B posted by dads b on April 03, 2008 at 15:43:35:
You need to remove No1 sparkplug near the radiator and bring No1 piston to TDC on the compression stroke. You will need a helper while one slowly cranks while the other holds his thumb over the plug hole to feel when compression is felt against his thumb. Then drop a LARGE handle screwdriver on top of the piston and watch that screwdriver rise as the engine is slowly cranked. When it quits rising your piston should be at TDC. Both valves on No1 piston should be closed. Your timing mark should be visible through that hole. It may be rusty too and hard to see. You should now be able to install the distributor by turning the rotor so it point's to the No1 plug tower on your cap. This should be in the 2 o'clock position as you view the cap. Then install the distributor. A mag is installed the same way. Hal
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
