something to check if you would crawl under the tractor there is a weep hole in the torque tube i cant remember where it is but make sure that weep hole aint stoped upsometimes the front seal for the transmission will weep fluid out and if the hole is stopped up the fluid will build up and can cause the clutch to slip my brother-inlaw and i where fixin to break our 560 in half to replace the clutch. his 75 yr old uncle said wait untill i can get over there. he crawled under there with a welding rod and unstopped the hole about a half gallon of stuff came gushing out of that hole i drove the 560 around about twenty min. no more slipping clutch that was about fours years ago still working just fine i would check the adjustment but i would try this also its a whole lot better than breaking it apart
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
