340 Utility blow-by oil bath air filter
Posted by hunter522 on April 08, 2008 at 05:36:30 from (74.62.92.106):
I did a compression test on my tractor and all 4 cylinders are around the 120 range. When I start up my tractor I would get blow by coming thru the breather on my valve cover and then it would eventually have oil on the valve cover and motor.
I have since piped with flex pipe & pvc from my valve cover to my rear axle so I at least dont have to breathe that stink.
I noticed yesterday that when I removed my oil-air filter the smoking stopped from my valve cover? No blow by at all. I am using a non-detergent oil.
Do I need a thicker oil bath oil?
Can I take off the oil air filter & replace it with a air filter (a junk-yard run to remove a complete air filter system off a car)?
If I take off the oil air filter & replace it with a automotive type air filter, is there any chance of hurting the engine?
Will a automotive air filter give me more power?
Thanks for the help.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
