Re: 7130 issues
Posted by JayIHMan on April 10, 2008 at 16:51:27 from (65.64.191.81):
In Reply to: Re: 7130 issues posted by chucky on April 08, 2008 at 17:48:10:
On the left hand side behind fuel aux tank (if equiped)you will find the hitch valve. Locate the small line that goes to large pump on right side of unit, cap off line that goes to the hitch valve. This will require a face fitting(Flat) plug to do this. Start unit and see if remote flow is regained. You also mite have had an orfice come loose in priority valve located behind remotes next to transmission. I would suggest a visit to your local Case dealer for the plug to block the signal line. Hope this helps.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
