Re: oil pressure transmission line
Posted by r4etired on April 10, 2008 at 19:39:53 from (166.226.229.126):
In Reply to: oil pressure transmission line posted by Mike CA on April 10, 2008 at 17:30:45:
If you have a guage from IH you will need an 1/8in coupling and a male compression ftg with a ferrule sized for your line, Early M's and H's came with an 1/8in OD line, the later have the small line. lot's of them have been altered so check your size.The line will be tight if you find the correct ftgs when your done
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
