The ferrule (second in) needs to be replaced. It should be tapered on both tube, and fitting ends. The tube should go through the fitting (about 1/8"). Put the left compression nut on the line first. Then the Ferrule (on past the end as above), the stick it in the right hand components(which should be screwed on the gauge already). Hold the tube into the fitting while tightenein the compression nut to assure it stays on far enough. It should tighten well. Before doing any of this, be sure the gauge works.Putting air pressure on it from a regulated source is best. 1/2 scale should be about 40PSI.. If the tractor still does not move the gauge, do not operate it till the issue is fixed........ JimN
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
