Posted by Janicholson on April 11, 2008 at 16:44:03 from (64.83.197.92):
In Reply to: H motor rebuild posted by landlord7012 on April 11, 2008 at 15:42:36:
I would drill a series of tangent ooles (about 1/4"drill) to remove the top of the piston. Then use a muffler chisel to cut down the inside of a drilled hole to split the piston (90degrees from the wrist pin) to collapse it. Then remove the piston. The sleeve can be expanded so much from corrosion of thepiston rings, that removal can crack the block casting under the thin sleeve. JimN
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
