Dan, Several things can cause this, to get it primed locate a plug on the left side below the oil pressure sending unit, it faces the rear of tractor and takes a 5/8 wrench. Remove that plug then apply air pressure to the filler dipstick tube "no more or no longer than needed" at the same time crank starter until oil squirts out. Replace plug and start engine. If pump and unit is okay this should get it working, if the problem repeats itself you may have a bad pump or an air leak caused by a poor o-ring, then find a good mechanic to help you. Good luck, Chuck
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
