Either one will be on the right side looking forward. Does the large wire to the center of the distributor cap come out of a round coil? If so, that would be battery ignition. If the wire comes out of a rectangular cap on a boxy looking affair, you have a magneto.
The push pull switch is different for the two. For coil ignition, it has two poles on the bottom, and the switch make and breaks the connection of the voltage to the coil. The switch for the magneto has only a single pole and grounds out the magneto when pushed down. A wire runs between the switch pole and a screw on the side of the magneto) to kill your engine when pushed down.
To make the two-pole switch work for a mag, you could run the wire from the mag to one pole of the switch, and run a wire from the other pole to a good ground. It'd work but it would work backwards, , i.e., down to run, up to stop.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
