Posted by bigr on April 14, 2008 at 13:35:46 from (209.225.102.58):
In Reply to: Re: 10-20 start-up posted by Bob Kerr on April 13, 2008 at 19:27:15:
It has the E4A mag on it. That was the replacement, I don't remember what the original was that I haven't seen for a while. It has new plugs, new wires, fresh oil change, radiator clean and full. I put a single pole mag switch on it because I couldn't figure out how to shut it off. My mag lever works front to rear not side to side. If you look at the aluminum cap from the seat, the cap to the left would be off and the cap turned towards the right a 1/4" would be starting position, correct? At that time you would turn the mag switch on, correct? As far as timing I would get the front cylinder to TDC and then the cap on the mag should be at no. 1? I'll try sending you photos. Thanks!
Today's Featured Article - Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
