Two specific things: If the loader has double acting cylinders on the lift, and the top of the cylinders are used for oil storage to supplement the resivoir, then one prospect is one of the cylinder is bypassing fluid past the piston. (it only takes one of them to leak to cause the problem). If the cylinders are single acting, the bypassed oil will be trapped above the cylinder, and either cause the cylinder to stop at some point short of extension, or squirt oil out at the point where the ram comes out. If the cylinders are double acting, and not connected as a resivoir, the oil would come out of the top cylinder port.
The other possible issue might be either a faulty or stuck relief valve in the pump, or a leaky control valve allowing hold pressure to bleed off into the resivoir.
Test. Hold the loader up in the air with a chain fall or other reliable adjustable lift. Cap the line going to the valve (lift line). Let the loader have its own wt. and if it drifts down, it is cylinder bypass. (be careful of the loader falling, be safe) If it stays up, it is a valve or pressure regulator problem. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
