Re: advise on clutch replacement?
Posted by CNKS on April 17, 2008 at 10:57:14 from (216.144.104.128):
In Reply to: Re: advise on clutch replacement? posted by bjc on April 17, 2008 at 10:48:33:
Does the TA work -- If you can separate the TA slippage from the clutch, put it in 2nd or third with the TA in low range let out the clutch and stand on the brakes. If the tractor slows as it should the "TA" is likely ok. Clutch replacement at a shop is likely several hundred dollars, TA replacement much more. Replacement TA alone (parts only) is about $600?? Remember that when either is installed, the Clutch and TA each must be adjusted. I'm not an expert on either.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
