Posted by Owen Aaland on April 17, 2008 at 20:40:19 from (65.165.246.73):
In Reply to: 2606 brake balls posted by bc on April 17, 2008 at 06:41:26:
As you pull on the actuating rod the links pull on the actuator plate to apply the brakes. The way the brakes are designed they apply the most force when the actuator just starts to move. As you pull farther out on the rod the angle of the link changes so that they will no longer apply as much force as they continue to move. Adding washers may give you a hard pedal but you will not have much braking action.
You have four surfaces that wear in addition to the disks. You need to remove enough material from the mating surface from the cover to compensate for all the wear. On 560s I have removed .125 to get good braking action.
It sure would be nice if someone were to manufacture disks with thicker lining to compensate for the wear.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
