Posted by JimB2 on April 20, 2008 at 18:18:09 from (99.241.179.24):
In Reply to: 584 Air in brake lines posted by dzwoodcutter on April 20, 2008 at 11:44:24:
Cutter, here is a test for leaky brake piston seals from Bernard le mécano who was CIH mechanic and had worked on these tractors a lot. Bleed the brake system, stop the tractor for 1 or 2 days and check one pedal at the time to see which is the side in trouble. Unlock the pedal to make the test, because, if you press both pedal, it has an equaliser valve in the system. The pedal that goes down has a leak in the piston. Bernard le mécano Québec Canada
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
