Re: replacing oil seal in super h rear end
Posted by Bob M on April 21, 2008 at 05:43:16 from (151.190.254.108):
In Reply to: replacing oil seal in super h rear end posted by Andrew Kappers on April 20, 2008 at 20:17:40:
Once that countershaft nut gets broken free it usually spins off easily by hand. Getting it broke free seems always to be a problem! A couple things that have worked for me. (Presumes you already locking the transmission gears…):
1 – Grab the nut with the biggest pipe wrench that can fit up in the belly and get a good bite on the nut. Some “strong arm” applied to the wrench handle will then break it free.
2 – Find a piece of square keystock that fits in the nut slot and is about 8” long. Lay one end of the keystock in the slot then give the free end a whack with a large hammer.
Here’s another I’ve heard about but not tried: Weld a piece of keystock to a large (eg. 1-1/4”) hex nut. Place the keystock end of the welded nut/keystock into the slot, then use an impact on the nut to loosen the countershaft nut.
Note! When reassembling the countershaft nut you only need to run it up hand tight – first time you use the belly pump the nut will tighten itself that last 1/16 turn or so!
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
