Farmall Cub Misfiring
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Ed E on March 08, 2000 at 19:39:51 from (209.240.200.184):
Sometime ago I put a message on here concerning correct timing of this cub with a magneto. Thanks to all who responded. Further investigation showed the magneto was shorting out. I got the magneto back from the mag shop and when I installed it and set the timing the tractor started without problems; however, the number 2 cylinder is not firing. I have checked the spark plug wire and have checked the plug. I even put the plug in the wire and grounded it to the engine and I get a good spark but when the wire is hooked to the plug in the engine it does not fire. This engine has been recently overhauled and I believe there is a compression problem either with the valves or possibly a scored piston or broken or improperly installed rings. I would appreciate any information anyone would like to share concerning this problem.
Thanks for your help,
Ed E
Post A Followup
: Re: Farmall Cub Misfiring
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
