Posted by JSharp on April 22, 2008 at 11:38:09 from (12.29.144.7):
In Reply to: IHC 404 hydraulics posted by mickey350 on April 22, 2008 at 02:46:33:
A good place to start -
Pull the hydraulic filter canister, clean the pre-filter screen and replace the paper filter. Mine like a couple of others I've heard of was clogged so badly the suction of the pump had collapsed the pre-filter screen. The 3pt was slow or wouldn't work at all depending. I don't have power steering.
Before you reassemble everything go to caseih.com and look at the diagram of the filter assembly. Make sure you have all of the parts in the assembly and they're installed in the correct manner.
If the fluid is milky you should replace that too before you fire it up and clog the new filter. Make sure you drain the bottom of the rear housing and also the upper 3pt case. There's one plug on the bottom of the rear drive case, and the upper plug is on the right rear side of the 3pt housing in front of and below the rockshaft.
You'll need 7+ gallons of HyTran or equivalent UTF to refill.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
