Re: H/M Steering Wedges (Narrow Front)
Posted by Janicholson on April 22, 2008 at 14:19:05 from (199.17.6.122):
In Reply to: H/M Steering Wedges (Narrow Front) posted by Red Mist on April 22, 2008 at 10:16:01:
Mike,
The positive and negative caster idea can be confusing. The location of the contact patch of the tire on the road compared to the orientation of the axis on which the steering wheel turns is the basis for positive caster. Take a caster wheel on a shopping cart. The pivot on which it turns is vertical. the contact patch is an inch behind the point on the floor through which the pivot would project (its axis). This is positive caster. and is just the same on the Farmall.
On a Motorcycle, the rake angle of the steering head is tilted toward the back on top. This gives positive caster by projecting that axis out in front of the tire contact patch (causing self centering, with differing amounts for different rake angles. all the way to the rediculous angles found on extreme choppers that do not steer well)
So positive caster is more distance between the point of axis and the contact patch, and less happens until there is none, at which point the axis and contact patch are on the same center.
Negative caster would be if the contact patch was in front of the axis, then the wheel would want to turn around and follow (like on a shopping cart) Though narrow fronts have two wheels, the effect is the same as though it had one. (think of a chair caster with two wheels).
In cars we adjust the ball joint location (to the front to lessen, and the rear to increase caster). I hope this makes sense out of it. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
