Well there could be alot of things going on here . With the low side out the sprag in the T/A is toast and there could be a bent lube baffel or the dump valve is sticking or the MCV pump is on her way out and the list goes on . SOOooooo to cure this it is time to replace the T/A and rebuild the MCV and install a new MCV pump and while your at it now is the time to do the engine clutch and PTO input shaft with a new bearing and all the seals along with grinding the flywheel . And if this is all done correctly it will last many years .
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
