no luck with touch control
Posted by John in SC on April 25, 2008 at 20:23:56 from (64.150.146.245):
Well here is an update.I received a gallon of hy-tran fluid today.It was recommended by the dealer. I drain out the other hydraulic fluid and replaced it with the hy-tran. Needless to say no luck. After a while I did find a weak spot. It started to leak around the connection rood on the d/s. I then proceeded to do a pressure test. I have a 0-200 lb gauge. I placed it on the high pressure side of the manifold tubes. At wide open the gauge only registered 15lbs, 2lbs @ idol. I can see why the lift will not work. : (
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
