Posted by Bob M on April 28, 2008 at 11:07:18 from (151.190.254.108):
In Reply to: Farmall H weak start posted by Wisconsin_Joe on April 28, 2008 at 10:20:06:
Sounds like a tired starter. However it could also be a failing starter switch, a weak battery or possibly a faulty terminal crimp on one of the new cables (it CAN happen…)
Also if the grounded battery cable is not clamped under a bolt that’s directly into the transmission or clutch housing (ie it’s bolted to the battery box sheetmetal) relocate it.
You might try this: With the ignition switch off, crank the engine for 5 – 10 seconds. Then quickly feel the starter switch and each cable terminal. If any are hot to the touch you’ve found the problem.
If all the above check out, time to pull the starter for a peek inside. Most likely the brushes are worn, commutator is dirty, bearings are dry, etc. A trip to your local starter/alternator shop is then in order.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
