Re: cracked head??
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Peter on March 09, 2000 at 16:18:08 from (216.78.11.187):
In Reply to: cracked head?? posted by Sly on March 19, 1999 at 15:53:46:
There is a kit to check for combustion by products in the radiator avialible at NAPA stores and elswhere. this will tell you if the antifreeze is coming from the head/head gasket or sleeve. If it checks bad get a spark plug adaptor and rotate each piston to TDC. Fill the cyls w/air one at a time, on the damaged cyls water will blow out the radiator.
If there is no combustion by products, drop the pan and pressurize the rad. Water will likely leak from the sleeve o-ring or elsewhere.
I just opened Advanced Cast Weld Inc. I have 22 years experience and I am a ASE Master Engine Machinest. (I repair broken castings!)
Peter Sattler
337-457-0908
Post A Followup
: Re: Re: cracked head??
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
