Re: Governor problems? on Cub
Posted by Bob M on April 29, 2008 at 11:44:56 from (151.190.254.108):
In Reply to: Governor problems? on Cub posted by Tab on April 29, 2008 at 08:54:13:
Most likely however it's a lean carb idle mix. Try running the engine and when it begins to surge VERY slowly pull out the choke. If you find a choke setting where the surging stops it's either the idle mix adjustment or a vacuum leak.
Now with the engine warmed up and idling slowly turn the idle mixture screw in or out 1/4 turn at a time until the surging stops (you may need to reset the idle stop screw afterward to slow the idle back down).
If you can't cure the surging with the there's probably a bit of junk (rust, etc) plugging the idle jet. Time to go inside the carb for a cleaning.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
