Re: Correct way to adjust a pressure plate.
Posted by Owen Aaland on April 29, 2008 at 15:54:17 from (65.165.246.73):
In Reply to: Correct way to adjust a pressure plate. posted by MAGMAN on April 28, 2008 at 17:23:02:
MAGMAN said: (quoted from post at 17:23:02 04/28/08)
What is the correct way to adjust a pressure plate? on the tractor or tight on the fly wheel? on a flat surface?or what?
JON
The correct way to adjust the clutch is on a flat surface. They will be two adjustment measurements. One is the distance between the friction surface of the cast plate and the underside of the clutch cover at the mounting bolt holes. The other measurement is the distance between the friction surface of the cast plate and the levers at the point where the release bearing make contact. These dimensions are installed heights so you need some way to hold either the cover or the levers at the correct dimension while you make the adjustment to get the other dimension correct. It is one of the last steps the rebuilders do when remanufacturing a pressure plate assembly. These adjustments are made to very close specs, usually within a couple thousands of an inch. All the rebuilders I know of do not want any field adjustments made to their rebuilt units. If there is a problem they will exchange it.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
