Durk: Probably just as well you raised this. I do have all 4 wiring diagrams in the history of the 140, and you caused me to look again. The starting went from pull rod with starter switch on starter, to your type with starter switch in dash, and the key start with solinoid. That solinoid is not on starter. Diagram is not clear but it looks like it's between battery and starter.
Prior to serial number 26800 they were all 6 volt postive ground same as 100 and 130. After that it was 12 volt all the way. 26801 to 45000 is same as yours. 45001 to 57723 has key start with solinoid ( IH are calling it a magnetic switch) Four way flashers were added in these. 57724 and above have alternator, quite a bit of dash change, plus they have a neutral starting switch. I presume tractor has to be in neutral to start, as a wire runs from that switch in the gear shift area to the key start. It's in same harness with rear lights.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
