Test number one: Remove the wire from the F terminal mon gen. Start the tractor and set to 3/4 throttle. Use a 14 ga jumper to ground the F terminal. If it now charges, the gen is good and the cutout relay in the regulator is good. The ground of the regulator needs to be made absolute, or the regulator field control points windings, or resistors are toast. If no charge, with the F terminal still grounded, and tractor still running at 3/4 throttle, jump the Gen and Bat terminals across the regulator with a solid piece of insulated copper wire, 12 ga, or 10 gauge. Make a good connection. If charging now the regulator is toast. Disconnect the big jumper before shutting down. These tests completely eliminate the regulator one internal part at a time. Good Luck, JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
