Posted by Wayne from MN on May 05, 2008 at 09:04:04 from (66.228.243.49):
In Reply to: 1940 H problems posted by Cpieper on May 05, 2008 at 06:55:11:
1. Open the high speed FUEL mixture screw so you can run at max RPM's, let the engine warm up, & re-adjust the high speed screw for max speed & smoothness. Add 1/2-3/4 turn out for extra power. 2. Idle the engine & adjust the idle AIR screw for smoothest running & turn the screw IN 1/4 turn extra for a bit of richness to reduce acceleration stumble & the need for choke. 3. Re-set the idle speed to 500 RPM or so. 4. Now repeat the entire process to verify all screw settings. Service manual & carb kit instruction settings will just get you "in the ballpark" so you can make the final adjustments. If any screw adjustments cannot be performed, the carb needs cleaning.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
