Re: 140 Transmission Oil Capacity ?
Posted by Dave BN on May 05, 2008 at 14:03:44 from (75.119.56.74):
In Reply to: 140 Transmission Oil Capacity ? posted by big red 1 on May 05, 2008 at 10:53:36:
If you are changing the gear lube you should drain the belt pully seperately using the small pipe plug on the bottom of that casting. You can refill the belt pully thru the plug in the top of that casting but it will gradually refill thru oil lines from the transmission. If your going to use the PTO for a mower or such I would pour a pint or so into the belt pully casting so it is lubricated right away. Oh, and you should change the lube in the final drives also if it hasn't been changed recently. Dave
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
