Oil will drain out of the filter housing almost as fast as you pour it in with the cap bolt removed, but in the front of the housing (inside) is a small hole near the top. that leads to the oil galleries, the same as the allen head plug mentioned earlier, and is normally easier to get too. Use a pump can to fill that opening. You can even leave the cap off and watch it start pumping by spinning with the starter to make sure it has primed.
Loosing the prime from just setting is not normal. The first time you have the oil pan off, you might want to make sure the pick-up tube is tight where it attaches to the engine.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
