Posted by trulyred on May 08, 2008 at 17:36:10 from (67.219.79.167):
In Reply to: 806 hydraulic posted by Elvin Winans on May 08, 2008 at 08:33:52:
You have very little or no MCV pump pressure. Pump is behind valve on left side of TA housing, it operates steering, brakes, TA, and lube. Sorry to say that if the tractor won"t move your TA is out on the low side "Be sure the tractor is in neutral & park lock is set" What happens most often with these symptoms is that the gear on the pump has sheared the square in the pump shaft. Probably will take a new pump and the MCV should be rebuilt while it is off.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
