'69 856 brakes....
Posted by Dan Swanson on May 11, 2008 at 15:39:42 from (63.172.252.161):
Posted last weeek that I had a lot of chatter in both brakes on my 856. Was suggested I clean out the small holes to let the dry matter out. Crawled under the tractor and use a small wire to open them up on the left side that chattered the most after I opened up both holes I got some black dirty wet oil on the wire. The holes are clear now no oil actually ran out of them. Just a drip or two. This tactor has several minor leaks above and ahead of the brake covers. DOes this mean there is a seal somewhere that is letting the oil into the brake disks? Also, as I mentioned before when I pulled the transaxle plugs they seemed to be way over full but I didn't drain them down to the top plug level. Could some of this oil be causing the problem from being over full?
Thanks, Dan
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
