Posted by mkirsch on May 12, 2008 at 06:50:13 from (64.80.108.52):
In Reply to: 1953 Super- W4 posted by Dusty Jones on May 12, 2008 at 03:41:41:
It's an updraft carburetor. The gas/air mix has to move upwards a few inches to the intake manifold to get into the cylinder.
There is absolutely no way for that quantity of gas to flow from the tank to the crankcase through the fuel system without involving cartoon physics, or one-in-a-million circumstances:
Normally if the float was sticking on the carburetor and gas was pouring through, it would start to run out through the air cleaner hose or a drain in the carburetor. Theoretically, if the tank were full, the drain plugged, and the air cleaner hose sealed, the gas could fill the air cleaner and intake manifold. However, when he tried to start it, he should've gotten a gasoline shower because the intake manifold and air cleaner would be full of gas too! I would think that he'd mention getting soaked from head to toe with gas when he went to start the tractor.
How would you get that much gas in the crankcase without something being obviously wrong? I don't know. It shouldn't be possible. The tractor would have to have been running poorly for quite some time under heavy use to pump that much gas vapor up and over the side of the engine. THAT is why people are skeptical.
Frankly, I think he drained 2 gallons TOTAL out of the crankcase, which isn't much more than what a C169 engine holds normally. It smelled like gas because the engine had some blowby. Maybe there was some raw gas in it, but not 2 gallons.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
