There may be an issue with the coil, or distributor shaft bearings. When it is running poorly, or stops, feel the coil if it is as hot as a fresh buscuit, it is toast. Wiggle the distributor shaft (up and down, not in and out) if it has motion that can be felt with your hand, it is probably worn enough to give irratic timing. It may be able to set the points (.020") but as it turns, the cams opening the points change the gap and thus timing varies. I point these out to make sure you are on the right rrack with the fuel issue. They can disguise each other. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
