If the tractor has a belt pulley gear box you can tell which direction to look for the problem. Put it in gear and see if it turns with engine running and clutch engaged. If it has power, the problem would be in transmission, differential, final drive or axles. Or pull tractor with it in gear engine off clutch engaged and see if the belt pulley has power. If it does the problem is between transmission and engine. If it doesn't have the gear box the cover plate can be removed or the cover plate over T/A unit to narrow problem. Besides already mentioned in other posts the splines on the coupling of clutch shaft to T/A unit can wear out and strip. Also if the T/A unit was already not pulling on the low side and the T/A clutch failed all at once the tractor won't pull, the splines can wear out in center of clutch disc or on the T/A input shaft also and fail.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
