Posted by ScottyHOMEy on May 20, 2008 at 07:20:50 from (71.241.206.235):
In Reply to: B needs help posted by mailman on May 19, 2008 at 20:19:00:
If the motor turns freely (If you don't have the hand crank, put it in fourth gear and see if you can roll it by pushing by hand on the rear wheels), I'd put some new plugs and fresh gas in it. Probably clean up the points, and see if she'll run. IF so that's half the battle.
Which way is the choke lever stuck? IF it's s stuck open, you can try choking it, just to see if she'll start by taking the cap off the intake of the air filter and covering it with your hand for a few turns, then remove your hand.
It's just as likely if not more so that the choke is stuck inside the carb rather than on the linkage, so you may have to fiddle with the carb some. If you take it off for a quick cleaning for the initial start, make sure you get the gasket between it and the manifold back in place and snugged up good.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
