Posted by Tracy H on May 20, 2008 at 17:01:09 from (75.138.209.130):
I just bought a 140. The tractor was running when I got it. But when you used it And go to cut it off it wonted to keep running. So I checked the timing it was so erratic that I could not set it. So I pulled the distributor. The distributor was so bad off I replaced it and the drive gear. My shop book saides to set the ignition timing to 22 dreg with s.n. up to 103556 if the s.n. is 103557 and up it should be set at 14 dreg. The s.n. on my block is 100646. I set the timing on 22 dreg and when I use the tractor it runs good. But when you cut it off it wants to keep running it is not running hot it is about 160 to 170 dreg. So I changed it to 17 dreg and it doing the same thing. Do I need to go lower on my timing or do I need to look for something else. Thanks in advance Tracy
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
