In the forward half of the water pump pulley there is a bolt. Originally took a regular screwdriver to loosen. loosen thoroughly or remove (it has to clear the square keyway cut in the threaded pulley hub. If you are lucky the forward part forming the pulley will thread in and out on the pulley hub to loosen or tighten the belt. If you are not lucky you'll have to use some PB, WD40, etc and clean some threads and possibly break out a big punch and hammer to get her moving... turn it in (toward engine) to tighten the belt, this decreases the V between the two halves, until you have desired tension. Line that threaded hole back up with that square slot and reinsert the bolt you removed.. While you are at it, give the grease zerk a shot or two of grease...
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
