Wellsy - Even if the resistor has failed the generator should still charge hard with the light switch set to the "H" position.
Most likely the ammeter box cover - and thus the switch - is not grounding to the tractor frame. Another possibility (long-shot...) is the LHDB switch has failed.
Tip - If you run your tractor a lot replace the cutout and manual control with a voltage regulator! It'll solve your field grounding problem. Also it will do a better job keeping the battery charged (and not overcharging....) than you can ever do with the manual control.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
