Posted by Janicholson on May 23, 2008 at 09:44:09 from (64.83.197.92):
In Reply to: 350 Water Pump posted by Jim McCarty on May 23, 2008 at 07:38:15:
The pulley is adjustable by closing the two faces together. The front half is mounted on threads. These threads are usually rusty and tough to work with. There is a set screw in the flange in the adjustable half. This must be removed, or loosened till it almost comes out. Spray it down with penetrating juice of yur choice. ATFluid is good. Using a brass drift tap modestly forward and back on the boss that the set screw is screwed into, and the blank boss on the other side. Be patient, and work at it gently. they are cast, and do break. If you can push in the middle of the belt span with your thumb, and it pushes in an inch or less with pretty firm pressure, it is correct. Looseness in this belt will still drive things. Too tight and the W/P bearings get overloaded. Tell us how it works out. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
