I need help before I cause another $1000 in damage!!
Posted by Butch WI on May 23, 2008 at 18:41:59 from (69.19.14.23):
Earlier this spring I was plowing with my 460 U when I lifted the plow and part of the fast hitch busted off the shaft that turns on the PTO, flush with the housing!! How do I get this heavy SOB back into the opening? I have the top 2 bolts (circled) started in the threads. Note the gap to close (in the oval circle.) The bottom 2 bolts (arrows pointed to them) are not yet started! I don't want to turn the top ones in for fear of not getting the PTO unit in squarely Any one have any Ideas? When I removed it I pulled on the shaft and wiggled all directions ALOT! until it came out. What are the chances that the splined coupler inside is not lined up? Here is a photo I hope...
If it doesn't show up it is in the Parts & pieces area.
[img]http://www.tractorshed.com/gallery/pieces/v5376.jpg
[/img]
Thanks
Hope to see some of you at RPRU!!!
Butch
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
