Re: Super M Clutch: Rejoining Tractor
Posted by Smith1000 on May 23, 2008 at 19:14:22 from (12.213.112.58):
In Reply to: Super M Clutch: Rejoining Tractor posted by Smith1000 on May 20, 2008 at 17:49:09:
I bolted the pressure plate down and then realized the clutch pressure plate has 3 small bolts holding the pressure off the clutch disc. Consequently, the clutch disc is loose inside and can rotate freely-even with the pressure plate bolts down tight.
I haven't rejoined it yet, but will in the morning. After getting it in place, I should be able to remove the 3 bolts to allow pressure on the disc. I presume it was set up to go back together this way. I imagine it will slide back together fairly easy without pressure on the disc. The 3 bolts will need to come out the bottom opening after it is together (clutch view opening).
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
