Posted by Owen Aaland on May 23, 2008 at 22:47:28 from (65.165.246.101):
In Reply to: H trans gears posted by Calif. Farmall on May 23, 2008 at 16:25:02:
Removing the top cover is not necessary to replace the input shaft bearings.
Remove the Lift-All pump assembly. Remove the drive shaft coupler. Remove the front flange of the transmission input shaft. Remove the bolts holding the input shaft assembly to the transmission frame. Remove the input shaft assembly.
The two input shaft bearings will be in the assembly you removed. The main shaft pilot bearing can be serviced through the opening where the input shaft was located.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
