Hi IntHarv, we had a 434(same frame as 424) do the same thing. Sometimes you could retrace your shift steps and get the gear shift lever to pop back into the correct shifter fork. Example yours is stuck in Rev and if you were going to second, then go to second and bring the shift lever half way over to rev side and go back to neutral and hopefully the shift lever will catch enough of the rev shifter to return it to neutral. If that doesn't work then do as the others have said, remove shift lever and align shifters with big screwdriver. See caseih.com and go to parts for 424 and rear frame page 89 has a diagram of the parts.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
