Re: Voltage regulator Bob M and/or others
Posted by Bob M on May 27, 2008 at 07:44:05 from (151.190.254.108):
In Reply to: Re: Voltage regulator Bob M and/or others posted by HENRY E NC on May 27, 2008 at 06:43:18:
"The next question is why does it not cut out when the battery is charged but I just realized that since it is charging at 8 volts it probably doesnt recognize full charge and just keeps turning out the amps"
Henry - That's says regulator relay is outta whack - that it is regulating at too high a voltage.
The regulator relay winding senses system voltage. When its set voltage is reached it pulls the regulator contact points open. This interrupts current flow to the generator field which causes generator output voltage to fall. When system voltage drops below set voltage the regulator points re-close, field current to the generator builds and output voltage again increases.
This open/close cycle repeats very rapidly (10 - 15+ times a second) causing the generator output voltage to stabilize at the regulator's set voltage.
Also the points open just enough (a couple thousands of an inch) to break the field circuit. So unlike the cutout relay, you cannot tell whether the regulator is working simply by looking at it.
Make more sense now?
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
