Re: Farmall 400 won't start.....+ ground??
Posted by karl f on May 28, 2008 at 15:43:45 from (64.83.221.111):
In Reply to: Farmall 400 won't start.....+ ground?? posted by Dan Anderson on May 27, 2008 at 14:42:34:
the factory ground is terrible on that tractor. if the ground cable is attatched to a battery box bolt that goes through the bottom into the rear cover, it's likely the culprit. disassembly and cleaning may help, but there are too many connections made with that cable and spacer assembly (my opinion). You could try running a ground cable all the way up to the starter mounting bolt; temporarily with a jumper cable.
also if you have the bolt on battery clamps, throw them away and get soldered/crimped ends. THe bolt on ends are designed to get you home. we've had nothing but battery trouble on machines where bolted on cable clamps are used.
karl f
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
