If there was no electricity going to it, and it still spun, the drive is in need of replacement. There is a new clutch style drive at the caseih dealer that is much better than the old style. If the copper pisec you refer to is the contact that is located on the side of the starter motor casing, and is just a "bump" of copper, it is originally intended to be a switch contact, and not be connected to with a cable. In this case, it may have had threads put in it to hold a cable with your non stock setup. A motor repair shop can install a new stud through the case with the ability to put an official nut on the real threads. It is possible to silver solder an adapter bolt to the stud you have, but W/O taking it all the way apart, the heat will melt the insulator. Best of luck, JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
