Most of them are in the 1.5 to 1.8 ohm range. Typical current draw is around 3 - 4 amps, which would translate to something on the order of 20 - 25 watts dissipation. Note that these numbers are with the engine stopped and the points closed; when the engine is running, the points are open a good part of the time and the average current draw is somewhat less.
The resistance and current numbers come from an old Motor's repair manual.
Easiest approach is to go to a good auto parts store and buy a ballast resistor for a 60's or 70's vintage car. NAPA has a universal one, part number SME 185450.
By the way, the reason for cars having external resistors instead of simply using a 12 volt coil was to provide a hotter spark for starting. There would be an extra contact on either the ignition switch or starter selenoid that would bypass the resistor and apply full battery voltage to the coil for starting. Once the engine started, this contact would open, putting the resistor back in line, and reducing current through the points to a value that wouldn't destroy them quickly.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
