Re: Super A Radiator
Posted by Hugh MacKay on May 30, 2008 at 18:04:17 from (209.226.106.24):
In Reply to: Super A Radiator posted by Rodger in Sabula on May 30, 2008 at 16:25:53:
Rodger: The radiators are the same up to serial number 336711. After that that Super A radiators were pressurized. Those pressurized radiators are physically the same size and will still fit, whether you should use one, I can't answer that.
At serial number 356001 there was another change to a physically larger radiator, it will not fit pre 356001 tractors.
There is another matter you have to watch if buying a new radiator for a thermosyphon cooling tractor, make sure you get the right core for thermosyphon. If you can't get a thermosyphon core, you'll have to add a water pump. I guess this could also apply to a used radiator. Thermosyphon cored radiators have been increasingly harder to find in the past decade.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
